Once the engine is warmed up you need to tie up to a dock, put it in forward, then adjust your idle speed. You should use a shop tach but presuming the tach on the boat is "accurate" that will get you really close.
And while your on the water you'll probably want to tweak your idle jets again, , , and then possibly the idle speed again.
As for idle jet(s) once the engine is warmed up and running in neutral, turn each jet out until the engine starts to run rough (too rich), then turn each jet in until the engine starts to run rough again (running lean), then back jets out 1/2 way between rich and lean and your good. Adjust one jet at a time.
