- Jul 18, 2011
- 19,021
The joint between the exhaust manifold and elbows on my Mercruisers have been showing some rust over the past couple of years. So, I had a gasket replacement on my pre-season maintenance list for this year. Today was the day to start into it.
I should mention that I have twin Mercruiser 7.4 MPI engines with aftermarket (San Juan Engineering) FULL closed cooling system. I run in salt water . . .
The SJE cooling system had the Mercruiser block-off gasket to separate the coolant in the manifold from the cooling water in the elbow. I was concerned about the longevity of the gasket, since it is pliable and could possibly wear through. My preference was to go with the stainless steel block-off plate sandwiched between two block off gaskets.
Here is a picture of the gaskets . . . The 'Quicksilver' is the standard gasket and the 'Barr' is the rigid stainless steel block-off plate. Mercruiser no longer has the plate, as they say the gasket alone is adequate (yea, right . . .)
When I disassembled the elbow, the single gaskets looked OK, better than I was expecting.
Since I had the exhaust system opened up, I used my inspection camera to take a couple pictures of the exhaust valves. Overall, I think they look OK.
I prepped the joint and re-painted the elbow. First with a rust reforming primer, then with gloss black topcoat.
Here is the Starboard side of the starboard engine all done.
I got 3 more elbows to go. The port side of the engines have the ECM electronics box and remote oil filter attached to the elbows . . . much more difficult to do those.
Since there are more gaskets between the manifold and elbow, I did have to make a quick run to the hardware store to get slightly longer bolts. Probably going to take the better part of another day to finish the other elbows off.
