lister
- Jun 29, 2015
- 141
I've looked all around including this site and cant find a guide on removing a Mercruiser 3.0 I4
It LOOKS to be just the two bolts on the front mount, then at the rear it looks like you loosen those two bolts and it'll slide forward?
I'd have to take the outdrive out also I would think as the drive shaft goes into the block there.
Appreciate any advice, thanks. My block is still cracked and I have a replacement (hopefully)
