smiles16
- Jul 25, 2016
- 186
Hey guys I had a post a while ago where I mentioned this, but it wasn't the main topic....
I have an '86 mercruiser 230 (305ci) with a Quadrajet. It had a fuel leak at the carb inlet when I bought it, took it apart and found the gasket and fuel filter were missing. So I picked up a new quicksilver filter kit that came with a new screen filter and two washers/gaskets. One large one and one small one for the inside.
Looked up some pics of these carbs on google images and I didn't see any of them using the large oring on the inlet. Which is it? I didn't use any teflon tape or pipe dope on the threads. Should I have?
Also, noticed on pics of other engines, the large spring attached to the throttle is attached to the front of the engine.... mine is attached to the rear. With that said, throttle will not return to seat with the idle screw on its own. Is this the problem?
Thanks, I'm not a chevy guy so I'm a bit lost.
