Slice of Life
- Apr 2, 2013
- 78
Installed my SE116 yesterday and torqued the nuts after completing an impeller replacement, and after putting oil back into the outdrive I noticed that the shifting boot was not aligned with the shifting (rod?) that's supposed to align inside the boot to shift properly. I removed the drive again to correct this, and was able to only have to remove it a couple inches to align the boot in and then push the drive back in. My question is this...in the few minutes that the drive was off with the new bellhousing gasket, is the gasket now already ruined? Is it absolutely necessary to buy a whole new gasket, remove the drive and install said gasket again after the drive being off for only a few minutes? Thanks.
