are you talking the water circulation pump or the raw water pump?
Bt Doctur has you covered for the raw water pump
the water circulation pump visually appears similar to the BBC short automotive pump, however it is a marine specific (brass impeller, stainless access cover). if you have heat exchangers, you can use an automotive pump, however the correct marine version is about the same cost.
