AKJohne
- Mar 26, 2017
- 220
I have a 1996/97 5.7 LX with AI GENII.
I bought this package used to install in a Glasply I have been redoing.
I could use some help sorting out a neutral safety switch, the prior boat that this motor came out of had a single handle binnacle.
I will be using a sea dog 2 handle binnacle that has no provision for mounting or attaching a neutral safety switch.
On the SB riser I have a PLT22 shift plate, it has the shift interrupt switch (87-808009T10) in the normal location. However there is a spot on the plate for a second switch, according to what I have found this is called a gear indicator switch (87-808009T11).
Do you guys know if the gear indicator switch is a N/O or N/C switch........?
The shift interrupt switch is normally open and I need a normally closed switch, I will use this to break the yellow/red switch to the starter solenoid.
Or is there a better way to do this?
FYI, I will be removing the shift assist cylinder
Thanks, John
Thanks, John
