Picked up a 23' Mariah late last summers to only have the engine fail after just 6 trips to the lake. I went ahead and had the engine rebuilt by a very reputable machine shop that mainly deals with race engines. The crank completely destructed. The engine is now back in the boat. The distributor is set to TDC, and the engine has been primed.
Can the first 20 min 2000 rpm be performed on the trailer in neutral? I was then planning on setting the timing at idle to 8 degrees.
What is the next step to ensure the rings seat properly? Do I just run the engine in twenty minute intervals at different RPM ranges. I've read the break in manuals online, but want to ensure it's done properly. Any help would be greatly appreciated!
Thanks in advance
Thanks in advance
