I am working on 496 Mercruiser I just had the engines out to do transom assy and put the engines back in and ran it and I had what felt like a dead miss throught the rpm range about every 3 to 5 seconds checked fuel psi to be high, replaced cool fuel because of paint delamination and replaced injectors still had same issue, did lea down test to be good 12% leakage on all cylinders, replaced spark plugs, finally I think it is ignition or electrical related, note I just replaced all battery's and alternators are charging as their are supposed to, I am stumped and looking for some advise on what next to do, I figure I am gonna run the boat on the computer and do a cylinder drop test to narrow down which cylinder is misfiring, also I did a spark test n a spark board and all coils have good blue spark that jump about a 1/2 inch gap, any help is appreciated. thanks
