I know it's a old post but did you get a alarm beep when the 1sec miss happened? I have the same issue and I'm leaning toward the coil being the issue. My motor will drop rpm for less then a second like the key was turned off and back on instantly. Seems to only happen once the engine is warm. I know I have to track all the ignition connectors but was looking for more info.
Thanks,
Mike
