OldRedToyota
- Feb 26, 2017
- 9
Hello All!
Got another project boat question for yall. I have 98 4.3L Thunderbolt V 2bbl Carb (Engine Serial 0M635945 Transoms Serial 0L263708), that when the boat was in gear you could turn the prop with a little pressure and hear a clicking sound. After a little google research I came to the conclusion that the cables needed to be adjusted and that changing the lower unit oil wouldn't hurt either. I changed out the impeller and lower unit oil and adjusted the cables per mercruiser specs. Noticed that if the boat was in reverse is "locked" and was good, the same thing happened in forward but I think I could turn it with some force and still notice clicking noise. Well today I got her running (first time in 5 years according to last owner) and when attempting to shift forward I needed to push forward before it would have a sudden "shift" then would go, in reverse it would shift sooner but still heard a noise. My question is, do yall think I need new cables or my lower unit needs some attention. When I fully shift into gear (don't remember which) the "guide" falls out of the tube (see picture for details). Is there a way to test cables, such as taking them off and manually pulling/pushing them to ensure that they are just worn and need replacing versus what I assume is a costly lower unit repair job.
Thanks again everyone
