CamaroMan
- Mar 18, 2016
- 324
Hi all - so since running our "new" baot a few heat cycles the past 3 weeks.. noticed today oil is a bit milky.. not completely peanut butter but like its half way there..
Did a comp test today:
1=145
2=143
3=145
4=139
5=150
6=134
7=155
8=148
Ill try pressure test the risers and manifolds 2moro.. should the block be filled with water for the test, and will a drop definitely indicate a crack, or could it just be a leak - intake perhaps?
Motor starts / idles super easy and all plugs look the same.. not one is clean from water - so i guess a blown head gasket will be ruled out for now.. Riser gaskets all look pretty good, perhaps 3 yrs old - nothing is majorly rusted / corroded - all bolts are stainless and came out perfectly.. no rusty water marks near gaskets either..
Im gonna run some used oil 2moro maybe and see what happens after shes hit running temps..
1=145
2=143
3=145
4=139
5=150
6=134
7=155
8=148
