littleguydave
- Jan 23, 2017
- 102
I placed the throttle in the forward position. I lined up the shifter cable. I went to slide on the outer unit and I needed to turn the spline. I went to grab the propeller to spin, but nothing. So I reached in and put the male end of the shift thing to the left right above the propeller, and then spinning the prop moved the drive shaft. That piece needs to be facing forward to line up with the bell housing right? If that end is facing forward then spinning the propeller doesn't move the ujoint
