A friends boat is powered by 260hp yanmar diesel which has a bravo 3x drive duoprop. When the motor was installed the raw water pick up on the drive was blanked off as the heat exchanger manifold etc is cooled via thru hull water pick up. He never had a problem for 2 years then started to get overheating in the drive. His gear oil in the reservoir is bubling up and spilling into the bildge after running after 30-45min at cruise. We put a shower on the drive which seamed to help but still happens after 45-60min. My thinking is the water jacket in the drive is clogged which is why the problem did not occur for first 2 years when it was new. I know the impeller is on the motor and since that was blanked off there is. Itching to suck water up from the drive, but thinking the design of the drive with the fins naturally forced water up thru the drive to cool.
Not sure the solution. I'm thinking need to split drive and clean. Also should the blank off plate be removed and the pick up be connected back to the motor with a T? Basically having 2 water sources thru hull and from the leg?
