08 350 Mag MPI: No Spark & Negative Turning Tach While Cranking. Banging My Head Against The Wall
Hi
I really hope there is someone wise here you knows exactly what my problem is I already had 1 "generic" boat mechanic look at the problem and 2 mechanics from a Mercury service center. Neither could understand what the problem is.
First off. Boat was working perfectly for 3 hours. Moored it. Came back a week later and no spark. When cranking there is no spark at the ignition coil. This of course rules out the distributor so I haven't even looked there. I have the newer type of engine where the ignition coil driver is screwed onto the coil.
My system has both a camshaft position sensor and a crankshaft position sensor.
I have changed the Ignition Coil, the ignition coil driver, the camshaft position sensor, the crankshaft position sensor. The ECM has also been changed.
I have verified continuiety of all the wires from the various sensors. See picture. I have also verified the neutral switch and gear switches and those wires to the ecm.
If I measure with a multimeter the wire coming from the ECM B23 to the IC Driver B (WHT/DK GRN in picture) there is a constant 5V when the ignition is on and when cranking. I dont know if this voltage should vary any when the ECM is sending the signal to the IC Driver to fire. If that is even what the ECM does..
Also what is weird, but maybe this is normal, is that I am getting +12V on the high voltage connector in the coil when the ignition is on and no change when cranking. Yes I connected the multimeter to the high voltage since I've given up and wanted to see if there was any reading..
I also replaced the grounding to the engine frame just to be sure there wasn't high resistence or something there.
Any clue? Please help
Hi
