- Mar 8, 2009
- 40,582
The bearing should be removed prior to removing bell housing, but can be installed at anytime but I would suggest doing it last. The exhaust boot is the hardest to get back on, and this is the reason many install the exhaust tube instead. The tube works the same as the boot but is not connected on the bell housing side. this also increases the sound heard while running on plane, but its not that much
In the link below are some vids and also a link from sterndrives. I like the write up by them and covers about everything
https://www.google.com/?gws_rd=ssl#q...t+instructions
