Mauro Brisola
- Jun 13, 2016
- 31
140 hours / 3 years raw water cooled 2013 350 MAG started to work with high than normal temperatures. Used on salt water. Depending on the boat load and the rpm temperature is "under control". Used to be steady about 163 F before. Now with low load (3 persons) and up to 3500 rpm temperature will be about 168/172. Can navigate hours this way. But with higher load or speed it could tend to aproach alarm zone (194 F). Problem is getting worse every time boat is used.
Engine oil is clean.
My bay "playground" has some tricky sand shoals. Then sometimes the drive unit "eats" some sand. Because of this I thought problem was raw water bad pump rub impeller related. But after dissassembling raw water pump I found the impeller in good condition.
Is possible to see too much corrosion. The iron water tube that goes under engine front is with a small corrosion capillary hole. It is possible to see water droping by one of the numbers.
After dissassembling this hose under engine front there was o lot of corroted metal "leaves" (picture). Is it "normal" to find it in a 3 years / 140 hours engine?
Despite engine is flushed with fresh water after every day trip, probably marina people did not flush well sometime(s).
My doubts:
-Considering this situation what's the most likely cause for the overheating? A bad circulating pump? Some clogged hose/place? Where?
-Have I to be much worried about the mufflers and risers condition?
Thank you for your input.
My doubts:
