jakehorton15
- Feb 16, 2014
- 66
I have a 1994 Bryant 180 with 4.3lx alpha one gen 2
Last year about half way through the season we began to take on water after using the boat in some log and stick filled water. It continued to seem to get worse throughout the summer, about 1-2 gallons every five minutes would pump out. I thought maybe a bellows had been torn by a stick or something.
So today I finally got some good weather and took off all the outdrive and bellows and gimbal ring. Everything came off easy enough with no problems. But I DID NOT find even the slightest rips or holes in the bellows even after washing and cleaning them good. All the bellows adhesive and rings were on correctly. The gimbal bearing and shaft were fairly clean with VERY little rust. But there was grease and a few drops of water inside the u joint bellows, and I was pretty sure I saw water coming in last year through where the output shaft goes through the gimbal housing.
There is zero play in the gimbal ring and housing when you try to move it side to side so I think the steering pin/steering shaft is good.
So is there anything else I should look for while everything is apart. Can it leak where the water intake hose and tube go into the boat or the trim sender grommet or anything like that? Any test I can do to check these things? I'm kind of stumped now since I was sure expecting a big hole in the bellows after all I'd read online and on the forums. Thanks, Jake.
