I had the boat at the lake over the weekend and a problem developed on the first day where it got really lumpy while at idle both in and out of gear. Then on day 2 it got worse to the point where it would cut out and be quite difficult to start. This is the first time out since I serviced it so we inspected the fuel filter for leaks and all the lines but couldn't see any issues. After the boat sat for 30 mins it seemed to idle OK for the first 20 mins or so but then after some skiing went back to being lumpy and stalling.
It felt like it was running rich or a choke sticking open is the best way I can think to describe it. There doesn't appear to be an accessible mixture screw on the carb so I tried disconnecting the connection to (what I assume is) the TKS. After this the engine didn't stall again but I could still feel it running lumpy around 1200rpm when picking up a skier. With the TKS disconnected it was harder to start than normal and idled high at around 1000rpm.
The boat was running perfectly otherwise, right through the rev range anywhere above 1500rpm.
Can anyone point me in the direction of a fault finding manual for TKS on the 3.0? I've found one for testing the TKS Diode on the 4.3 and up but I think these are all MPI?
If there is somewhere else I should be looking please let me know, I'm starting with TKS because it didn't stall the rest of the day or the following day with it disconnected. Although I did reconnect it to start the engine first thing in the morning on day 3.
