ericcarr2000
Ensign
- Mar 19, 2010
- 903
Ok. I have a major delima. I have been battling trying to get ahold of the engine builder of my motor that has just 4 hours on it out of California, by the name of California engines. I know by now that I pretty much got shafted on the deal due to the fact that they will not answer the phones and I even tried to send a certified letter no luck? The problem that I had was the motor was mixing water with the oil the surveyor said That when he went to where the boat was the mechanic told him the reason being is because the camshaft was allowing water to mix through the exhaust valves due to the Cam being too big. So now I have this motor it's completely tore down and not sure what to do any suggestions? I thought about sending it back into a machine shop locally in having it checked for cracks & if all is good just starting the rebuild process over by myself what do you think?
