This is a tough one to figure out as there isn't a specific number rather multiple numbers depending on what diagram looked at and none of them are an 100% guarantee fit.
I'm thinking the those from the T cover to starboard manifold wouldn't have changed from a normal/standard cooling system which yours being an Alpha from new and adding the closed system there after may be part number 32-87117 1.
https://www.perfprotech.com/mercury-...0?umodel=24108
As for molded hoses, it seems there's one straight hose that covers a wide verity of molded hoses (though it's aftermarket) when looking at the many available closed cooling diagrams which is Sierra part number 18-75100... Molded Hose 48" which replaces Merc part numbers 32-89749, 89730-1, Mercury 32-16021-1, 32-19403, 32-33220-70, 32-41940, 32-52481, 32-87117-1, 32-89730-1, 32-89749-1 ...
http://www.iboats.com/Molded-Hose-St...view_id.172089
If you haven't yet and still want to try and find the correct molded hose by design to fit as some like to do in order to make installation a bit easier etc., you may want to try removing the hose, get a good photo of it then search the multiple hose numbers by image/online photos + from eBay until you believe to have found the right turning angles to match yours.
Two possibilities for molded are,
HOSE (STARBOARD) (# 32-871171) http://www.mercruiserparts.com/871171-hose
89730-1 HOSE, THERMOSTAT COVER (STARBOARD)
http://www.mercruiserparts.com/897301-hose-molded ,
http://www.crowleymarine.com/mercury...s/1998_600.cfm
Unfortunately there is nothing that stands out and says with certainty this part number or hose fits the starboard lower exhaust for the closed cooling system of your design as/like item number 30 does below for the port side which also seems to be a different number pattern than the usual parts diagrams.
