I have a 7.4 mercruiser , had trouble starting it this morning and when I pulled of the spArk errester there was oil on the top the carb and oil film on the errester. cleaned it up and ran OK, not sure what caused this
A picture might help, but usually, the oil breather tube will allow a small amount of oil vapor from one of the valve covers to "condense" oil where it enters the intake.
Doesn't hurt a thing unless there's a lot. If that's the case, (with a high time engine) you might have excessive blowby.
