Weirdnerd
- Oct 15, 2016
- 35
I got a boat a month ago ( Sea ray 190 SRV) and I have been doing lots of research over here, the boat has not been run in ten years, it has been covered and winterized before put on "the pasture", upon inspection I found the thermostat housing was corroded, engine recirculating water pump corroded, spark plugs had surface rust but not pitted or corroded, I replaced the thermostat housing and the thermostat, the water circulation pump, the impeller on the lower unit, points and condenser, I am removing the fuel tank for a flush inspect and possible repair, I have been reading horror stories about water manifolds and risers on those engines and I will have to open and inspect there. carburetor had some dust on the arrestor but otherwise it looks pristine inside, wiring is going to have a spruce up, as well as I will have to inspect the instruments ( some look out of calibration like oil press and temp, RPM indicator and speed indicator).
My Question is : this engine has been outside for ten years without operation, It has been stored in very dry high desert, Colorado western slope, not much in the realm of snow, but sometimes it rains a lot. what do I need to inspect, fix or replace to make it fun ready? I have tools, but I am more used to gas turbines and aircraft reciprocating engines, this is my first time on a boat engine and I am trying to learn as fast as I can.
PS: I bought the SELOC manual for this engine and I have read it from cover to back a couple of times, but it does not give a spec of how often to replace items, ( similar to a scheduled inspection or "50 hour, 100 hour, annual inspections" etc)
