I've never pulled a boat motor an drive I've pulled many truck an car an semi trucks motors an transmission but never a boat
Ayuh,.... Welcome Aboard,.... Changin' the pan gasket, in the boat, is a fool's errand,...
Yer a Mechanic, 'n boats are
Easy,....
Pull the drive, then pull the motor up, 'n out,...
Most of the wirin' is 1 plug, unlike the other things you've worked on,...
In my shop, I can go from motor in the boat, to motor on the stand in 1/2 hour, an hour tops,... By myself,....
Btw,..... My '93ish 4.3l has 'bout 2,000 hours on the clock, 'n is showin' no signs of needin' any rebuildin',....
