So, after fiddling around with my motor (5.7 Vortec, re manufactured) all summer, I have one last issue/concern. I cannot get more than 43 mph/4,300 rpm's out of my setup. Company I bought it from says it should make maximum hp at 4,800 rpm's. It will rev right up to 4,800 and then cut out when the boat is in neutral.
Engine Won't Reach Operating RPM. Check
1. Fuel condition. Type and Octane possibly old fuel Only run 93 octane. 5 gallons at a time from one of several local gas stations.
2. Propeller pitch or diameter, damaged blades ACME 515. Definitely the recommended prop for my boat/motor/use combo. They say it isn't the prop selection.
3. Restricted fuel pickup tube or anti siphon valve Fuel System Test Performed all fuel system tests. It all looks good.
4. Crankcase oil volume, high oil level can cause aerated oil and lifter collapse Oil is right at full mark on dipstick.
5. Marine growth on hull and outdrive Freshwater boat, stored in driveway. Hull is clean, but not waxed.
6. Wrong gear ratio in outdrive Original 1:1 Velvet drive transmission.
7. Restricted carburetor air intake (clogged flame arrestor) Flame arrestor is clean.
8. Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive Exhaust is clear.
9. Poor cylinder compression Compression Test I have done multiple compression tests. 155 to 175 psi.
10. Carburetor defective, or wrong type. Problem existed with original 750 cfm Weber. Now have a new 600 cfm Edelbrock. Adjusted properly.
11. Fuel pump pressure and vacuum New Carter 6-9 psi, with FPR set at Edelbrock recommended 5.5 psi. Does not go below 3 to 4 at WOT.
12. Boat overloaded, improperly loaded, or improperly trimmed. One to three people in the boat when out on the water.
13. Engine Overheating Running new 160 thermostat. Temp gauge reads 150. Laser thermometer reads 150 at thermostat. Reads 180-190 right at heads.
14. Engine timing and ignition system operation Timing is right on. New plugs, wires, cap, rotor, coil, distributor sensor.
15. Remote control cables and linkage for proper travel to open throttle plates fully. No issues here.
The next thing I was thinking of replacing is the original Thunderbolt V distributor itself (probably with something simpler). Not sure how to check if this could be an issue. Boat is running great right now (just in time to put it away for the winter).
Thanks for listening!
