My drive was stuck in the up position at one point. I had someone push the drive down while im pressung the down switch. I finally went down. Its working now and i lubed the hydraulic rim shaft. Now its working up and down no problem, except i found some trim oil in the bildge, i think its when my buddy push the drive down that caused it.
Now, i cleaned the bilge, trimmed the drive up and down a few times, no more oil.
When i cleaned the boat after i used it the last time, there was no oil, and i didnt run the boat. Only thing i did to attempt to trim the drive up and down.
My question is, is there a release valve that releases too much oil under too much pressure? There is no evidence of oil leak coming from the pump or the lines coming from the pump. The only thing i cant see is the hoses under the y pipe ging to the transom.
