johnrmclean
- Jun 12, 2007
- 80
My 1994 454 Mercruiser has a knock sensor on it. What do they do and how do they operate?
does disconnecting the knock sensor have any effect on performance or the main ignition module?
Except if you get crappy gas or the timing gets out of whack and the thing starts to knock. That could burn up the engine.No
On your TB ignition it has no effect if it is disconnected
Why would anyone run disconnected?
IMO you don't run it disconnected unless for a quick test. My comment was just what happens if you do disconnect it on a TB ignition.
If it was a MEFI-3 or higher then the ECM checks to make sure the sensor is working when the boat is first throttled up. If it does not detect the sensor knock then a code 44 is set and timing is retarded thereby reducing power
