Bought a new "old style" coil for this boat and had some inquiry after doing a test on the coil. So, for anyone familiar with this, obviously, you know that the ignition coil is cylindrical in shape and has positive and negative terminals on it with a spot for a wire coming out of the top. This wire coming from the top center of the coil goes to the distributor.
So, I manually fired it with a bench test jumper cable method. From the battery, I connected a wire from negative battery terminal to the ignition coils negative terminal. Then, I took the wire coming out of the top of the coil and put it in my left hand and hovered it next to a ground source (a shiny bolt on the engine). Next, I picked up a cable which I had prior to all this connected to the positive battery terminal. I then executed the manual fire test. As I touched the positive cable coming from the battery to the ignition coil positive post I transferred spark throughout the coil and up through the top cable in my left hand. The result was a spark passing though this and creating a tiny arc going to the ground bolt, simulating a spark that is supposed to go to the distributor.
So, the ignition coil does work. However at the end of this line the arc or spark is supposed to be much brighter and stronger.
I tried using a different wire coming out of the top of the coil and I still had the same result.
Why is the spark or arc of the spark so tiny and weak??? it's supposed to be wicked bright.
