zdziarskih
- Sep 6, 2014
- 28
Good afternoon all.
I did a complete write-up on the timing chain cover oil leak fix last year on the forum (http://forums.iboats.com/forum/engin...=1472146868027) and I ran into a belt issue last weekend...
While at the dock, I started the boat and noticed the volt gauge was around 10 and immediately shut down the idling engine. Pulled the doghouse and found the v-belt was off the pulley's. I put the pulley back on and off I went. Went out about 3 minutes and noticed the gauge dropped to 10 again. At this point, I was at my house dock and pulled it in. I put the belt back on again, idled to the launch and decided to take it back to the house and have a look.
So, 2 things I noticed. The belt wasn't broke, but twisted, and wouldn't stay on the pulley's. The Harmonic Balancer pulley is now further away from the original position I had it in and is not inline which caused the belt to do what it did. Has anyone heard of this happening before? I would have assumed the pulley would stay in place... I did use the block of wood/hammer method to put it on but I wouldn't think that has anything to do with this issue...
Any thoughts? i am going to put it back in place with the hammer and wood again and see what happens I guess...
I did a ton of searching for a similar issue but came up empty
Thanks,
Harry
Thanks,
Harry
