ottawamerc
- Sep 16, 2004
- 128
I have a Sundancer 268 with a 260 in it, it has one battery for the engine start and 2 batteries for house power. 2 weeks ago when I went out in it I noticed that it wasn't charging the batteries so I tested the alternator and sure enough it wasn't putting out any voltage. I had already replaced the voltage regulator on it in the spring and it seemed like it was blown again? I took it to a alternator repair shop and he confirmed that it was blown but also recommended that I should use a 65 Amp alternator since I had 3 batteries instead of the 55 Amp stock alt. Seemed reasonable enough to me so I bought the 65 amp one. Last weekend I used the boat again, I was on the house power all night and in the morning when I started the boat it wasn't long before I was smelling electrical burning and the volt gauge was reading low. I stopped to check and found the alt was really hot so I switched off the house power at the battery switch and just left the engine battery on and the volts came back to 14v and it worked fine? Is it possible that the stock wire that goes from the batt terminal on the alt to the starter is too small now? or is something else causing havoc on my charging system?
