SHickey
- Apr 29, 2011
- 237
Hello,
After using my 1976 Starcraft 20' American (165 HP & MC-1 O/D) all over Keuya Lake for vacation I noticed my outdrive was failing to go up all the way if I was in shallow water. Going down was fine but going up, I needed to hit the down button and up button rapidly until I could hear the oil pumping but still the unit only partially went up.
At the dock I added a little bit of oil to the reservoir and it did work better going up 1/2 way but still not all the way up. Not sure what to do at this point, I see no obvious leaks around the pump or the hoses and it seems to go up to the 1/2 way point and nothing more.
Any suggestions or tips for getting the trim/tilt unit working properly??
