I want to repair my skeg before I reinstall the outdrive. It broke off years ago, don't even remember how. Anyway, it is an Alpha One Gen 2. What are the approximate dimensions and thickness of the skeg, I can trim it for final fit. Is there any concern that the brake is right up to the bullet/gear case other than the heat issue and the seals inside.
Thanks again.
Thanks again.
