badbowtie
- May 18, 2007
- 634
I am trying to help a good buddy help work on a 97 350 magnum 300 hp that he just got 3 weeks ago only had 100 hours on it. I know the previous owner and he has owned it for 13 years and had it sitting in his garage for the last 5 years unused, 3 weeks ago it ran great when they water tested it so he went ahead and bought it. The next day he had his family in it and said it just ran horrible. Barely would even get on plane and took for ever at wide open throttle to only get to like 35 mph and 3800 rpm. Then next day they put a new water separator filter on it and took it out and same thing for the first hour of the day then it coughed once and ran great again like 5000rpm and 65 mph like normal again. Thought it was all fixed went back out yesterday and ran like **** again so this morning I went over and replaced the water separator again thinking it was a fuel problem. So I unscrewed the dist screws and the terminals were all corroded so I replaced rotor and cap and figured for sure I fixed it. So went back to the lake in between the rain tonight to fins out same thing still don't run right. I drove the boat tonight and you can go wide open on the throttle and it don't even pick the bow up and go. It takes for ever to get it to finally pop up on plane. We are talking like over 100 yards and can't get any faster than 40 mph playing with trim even like 400-500 yards. Never could get above 4k rpm. It does not spit or sputter or anything. I am not sure what to try next I did pull all 8 spark plugs after running tonight and they all look good like they are all firing. I am just not sure what to try he has ran about 100 gallons of fuel and 4 bottles of sea foam thru it. Please help...
