mr300z87
- Sep 15, 2010
- 694
First some back history. Three weeks ago my wife and I went out for an evening sunset cruise, my lack of attention to the missing channel marker caused me to suck some sand through raw water pump into the water hose located under the engine and caused an overheat This is a BRAVO 1 with the belt driven pump. I shut the engine off before the alarm rang at 180 degrees, re stared and it quickly rose to 200 degrees and the alarm sounded I shut it off immediately . That night night I go towed, did some quick troubleshooting in the dark and determined no water going to engine. The next day I took off from work went to the boat cleared raw water hose and check raw water pump (Bravo 1) re assembled and all good. Ran normal temps 140 at no wake and 150 at 3000 rpm cruise speeds. I did run it a little harder than I normally do with no issues. The wife and I took her out again that weekend with no issues. The boat then sat all week and last weekend before leaving for our family beach vacation (no boat), she gave me a hard time staring which it never has before, but it started and seemed to be running fine. So we went out for a short cruise and all was well, and I again ran it hard (no wife) for a short burst, then about half way through the no wake area approaching the marina it developed and miss. Since we were getting ready to leave I only had a few min to troubleshoot. I figured it was probably carb or fuel related so I ordered new fuel filter to be installed upon returning home. So hear I am
Got home this morning, we had a great week in Ocean City NJ, and I figured I would go to the boat to do some more troubleshooting. As I always do I checked the oil and the gear lube, which looked good so I went to fire her up and much to my dismay it went clunk and the engine turned only a couple degrees and stopped. After a couple of bad words I determined that it was hydro locked. I pulled all 8 plugs and found water in cylinders 1 and 3 only(thankfuly my mainra in all the way up the Metedekonk river and is fresh water). After more bad words and a lot of staring. I continued to crank engine until no more water came out, I then sprayed WD40 in the cylinder and cranked it again them more WD40. Put all the plug back in cranked it one more time and left to go home and cry. LOL
I am pretty confident that is it not a riser/elbow or back wash issue because last year I updated the manifolds and risers to DRY JOINT type and the elbows are well above the water line at least 4 inches above Mercruiser minimum.
My plan of attack for tomorrow when I hope to get a helper is to do a compression test which I would assume would be low on cylinders 1 and 3 if it was a blown head gasket. Does any one know the marine felpro #? Also if it is the head gasket should I do both? In the water or out? What else should I look for? Would a mild overheat like I had be the cause? FYI my engine is a 5.7L Bravo 1 330 or so hours, the serial # is in my signature file. Thank in advance for any advice. Now is time for BEER and more crying. I have no time for this I want to go boating!!!!
Mike
Mike
