Having trouble installing a new shift cable kit and have now ruined 2 outer sheaths. This is getting expensive, time consuming and very frustrating. The first one we kinked while removing it (bellows install got out of order, long story). The cable inside the boat didn't rotate freely enough so the outer cable kinked. Bought new cable kit and have it installed correctly I think. I am trying to install the little spiral wrap on plastic protection section on and am assuming it needs to go down where the cable passes through the transom. There is no way to get to it. In the process, I find I've damaged the black outer sheath of my new cable. I have searched the forum and I think I have the proper cable routing. I just now found a video saying the spiral wrap on plastic protector is only supposed to be where the cable goes between the exhaust manifold / starter / transom assembly basketry. So I'm asking for some advice as to how to get the right parts, get them in the right place, and not damage anything in the process again. This is getting very frustrating and expensive (OEM parts as kits)!
Got a few questions (1987 4.3l Alpha One Gen 1, I have the manual but it isn't clear on these things as far as I can find):
1. Can you buy just the outer sheath of the cable or do you have to buy a kit?
2. Should I be able to remove / install the cable at the bell housing and have the cable inside the boat rotate freely enough to not kink the cable sheath?
3. Will the shift bellows rotate on the cable enough to not damage the shift bellows while removing old and installing a new cable?
4. Where exactly does that spiral wrap on plastic protector go and how do you get it there?
5. How compressed or expanded should the shift bellows be when you crimp or zip tie the shift bellows to the cable.
6. Is the cable supposed to route through the transom, then just above the manifold and behind the starter and under the transom bracket protrusions, then around manifold, behind steering cable and up top on the engine?
To top it all off, I wasn't having any shifting problems when I started all this work. I was just following the advice or replacing it while I have everything apart for a bellows replacement.
I would appreciate some help.
