Ok my boat only starts with one plug out doesnt matter which plug. Otherwise it will just keep turning indefinitely. The history on my boat. Boat was acting up where it wouldnt start some times. Then i took it out and it ran fine and died in water and got towed in. Rebuilt carburetor a few times and it would fire and run fine for quite a while then went back to start and it wouldnt. Repeated this a few times and realized that water and crud were getting in the carb. So i pumped out all the old gas and redid the carb again. No more water or crap. Changed water separator. Now it wont start at all. So i was checking for spark and getting spark to every plug. I took iut each plug one by one and it would actually start up and run great other than the one missfire. And it runs fine as long as either of the 8 plugs are out. Havent changed the plugs. Put in a new fuel pump which is working fine. Going to put a new starter tomorrow. Battery fully charged. Have 2 new batteries and wouldnt start with either. Help anyone? Boat is 1999 bayliner capri with mercruiser 5.0 thunderbolt ignition alpha 1 gen 2. 2 barrel carb.
