Hello guys, I have tried searching but haven't found much that has my full problem in it. So here goes. I put a new/rebuilt 4.3l merc in my 95 stingray about 4 years ago. have logged many hours since. When I originally timed the boat I did it in the driveway with muffs only, never on the water, but I have not had any issues with it since. For some reason this year after running the motor for a period of time, say 1/2 hr or more, once the motor is completely heat soaked. It will start popping at around 4k and wont be able to get any higher in rpms, and when this starts happening, trying to trim up cuts the power to the motor considerably. Now when cold the boat runs absolutely great, i can trim up and have no issues with cutting the motor power, only when hot. The longer I run the boat the worse it gets, till it wont even get up on plane. The pop I hear sounds like an ignition problem, not loading up and backfiring. Here's what I have done to try and remedy the problem. I have cleaned all power and ground contacts, to and from motor and trim motor, replaced coil, replaced cap and rotor, and new fuel filter (the old one only had 1 hr on it). I have no visible arcing on plug wires, i have 12.5 volts on new battery before and after i get off water. I have 13.5 volts from alternator at idle. I don't know whether I should check timing after it gets fully heat soaked, or if my alternator is possibly breaking up at high rpms once it gets hot, or if the electronic ignition module is going bad. I don't want to just keep throwing parts at it. The motor cutting out with the trim thing is what has me stumped. I am generally good with motors and diagnostics, but this is baffling me. Thanks in advance.
Kyle from Upstate ny
