nitedmn
- Jul 3, 2005
- 78
I'm working on replacing my lower shift cable. So far I've managed to get the old cable out and now I'm looking to get all the stuff I need to get the new cable installed. I have an old 1972 Pre-Alpha drive with the old style shift cable (screws in from the bellows side). From what I've read I will need to convert this to work with the new style cable. All the info I found for doing this was pretty old (some of it conflicting) so I'm just asking for clarification on the steps so I don't screw anything up.
1. I need to tap the hole so I can attach the new style cable like this http://forums.iboats.com/filedata/fetch?id=6951255. Is the part number listed in that image still valid? Are there cheaper versions of this tap I can look for (trying to do this as cheap as possible without sacrificing too much quality)?
2. To tap the hole correclty it sounds like I just need to screw it into the existing threads and use the tap to extend the treads all the way to the other side of the hole. Is this correct?
3. Which shift cable kit should I be looking for? There seem to be a lot of options and I don't know which one I should get. Again, I'm trying to go as cheap as possible but still have quality parts. It's a Mercruiser 888 if that helps to narrow it down.
