redmen62
- Aug 7, 2011
- 103
I'm finally on the last step of converting my port engine to counter rotating!!!
Put on my new port outdrive, bellows, zincs, props, and outdrive shift cables (both engines for the replaceable stuff) and I thought I was good to go... I guess I missed the step where I need to change the connection of the port shift cable on the shifter at the helm, however I'm at a loss how to get to the connection on the throw.
I found the set screw on the throws that allow you to slide them off, but I for the life of me can't figure out how to get to the cable linkages under the plastic cover.
I attached a pic of my shifters. They're on a 1983 regal 277 with twin 305's and alpha one drives
