richyiboats
- Jun 5, 2016
- 8
Engine year: 1982
Engine Serial #: 6209582
Make: Mercruiser
Type: Sterndrive
Sterndrive Model Number: 1/R Drive
Sterndrive Markings: 6135423 1.98R
Sterndrive Serial #: 6184027
My engine was overheating on my last boating trip (first outing this year). I suspected that the impeller was damaged, so I drained and removed the sterndrive lower unit, and confirmed the impeller was in fact damaged. I am in the process of replacing the impeller, and the upper pump housing. I am also replacing the water pocket cover, as it showed signs of overheating as well. While I was cleaning out the area around the water pocket cover (I was looking up into the upper unit), I felt a loose metal object sitting on the shelf of the upper unit casing, toward the front of the drive shaft. The object was just sitting flat and loose on the shelf. I could not feel any place in the area where it could have fit, nor where it might have been connected to another part. I pulled the object off the shelf. It looks like some kind of shim perhaps, or maybe a part that was dropped into the housing by mistake and left there by a previous owner/repair person (eeek!). It measures 1 3/4 inches across the base at it's widest, and 1 inch at it's tallest. It's about 1/16th of an inch thick, with 5 holes drilled through it. I'll attach a picture of the part, and one of the area of the upper shelf.
The piece was sitting on top of the squared area toward the bottom of the picture.
I need to know what this part is, so I can determine whether I need to remove the upper unit and reinstall the part.
Thanks so much for any help you can give me!
Make: Mercruiser
Type: Sterndrive
