Sullysllvn6
- May 30, 2016
- 3
I have a 1985 Mark Twain with a mercruiser mcm140 4 cylinder engine. I have been working on getti g back on the water. I had it on the lake this weekend and it seems to be getting gas in the oil. I recently rebilt the carb and mechanical fuel pump. The oil is grey looking and smells of gas. I have seen water in oil before and it always looks milky white but this has a grey tint to it. The boat ran really well it did not get hot,but i found oil leaking from the front seal a little and pulled out of water. My question is if the block was cracked would the boat still run well and with the oil having a grey tint instead of white is it gas or water? Also if i rebuilt the carb and fuel pump what else would cause gas to get in the oil or do you think it is water and possibly a cracked block. Thanks for any help
