Hi,,
I am having a problem with my 1984 sea ray Seville, mercruiser 3.0l .
It had some problems last year with taking off when I punched it, as in pulling up a skier, it would stall for a second before taking off.
So, the local, well known mechanic said it was a certain part in the carb ( I forget what it was called, but anyway) he replaced it and it doesn't have that problem anymore.
However, what it does do now, is after warming up, going fast for maybe 20 or 30 minutes, it drops rpm's all of a sudden (sort of) and then starts sputtering out and dying. It can usually be restarted, or if I catch it soon enough, and back off the throttle it will go along in low rpm's.
If you try to speed up much at all it will die again.
I changed the plugs, emptied the old stale gas and filled with premium non ethanol, also added some seafoam, cleaned the points, and changed the fuel filter.
Problem still exists. Today I went out with an extra tank filled with Premium non-ethanol gas and it did the same thing. So that would preclude stale gas, vapor lock, etc.
I am going to change the ignition coil this week, because I have read a lot about that perhaps heating up and not working.
Otherwise, just looking for some advice, or at least diagnostics to go thru before taking it back to the mechanic to see if carbs are just adjusted wrong.
I have no idea how to set them.
Thanks ahead of time
