mattmullen
- Aug 24, 2015
- 7
Hi Iboats,
I'm stumped and I need some help. I bought a basket case 1991 Sea Ray last fall.
Over the winter I worked on rebuilding the 4.3 v6 that blew up because of lean burn detonation.
It fires right up and runs on my home made stand but cylinder #3 is not firing, if I pull the plug wire at a variety of engine speeds there is no change. When you hit the throttle and as it comes back down it idles very poorly for 10-15 seconds and then evens back out. I have also noticed some condensation on the insides of the valve covers and the bottom of the intake manifold (I am not sure how much of this is normal I am new to marine engines). If I pull the risers right after running I see some droplets of water on the cylinder #3 side none on the other bank of cylinders. When I pull the spark plugs on that side #1 looks textbook perfect burn #3 and #5 look rich (all black and sooty). #2, #4 and #6 look textbook as well.
I have done the following
Pressure tested cooling system-It leaked down slowly from 15psi to 5 in a weeks time.
Leak down test-good on all cylinders
Compression test- good all cylinders at 150 psi +/- less than 5 psi
Checked spark- good blue spark on #3
Adjusted the valves meticulously
New Parts in rebuild
Pistons-.030 over Sealed Power
New Roller Lifters
Rebuilt Heads
Edlebrock 1409 Marine Carb
Edelbrock Performer Manifold
Delco Voyager EST Ignition/Distributor
Aluminum HGE Exhaust Manifolds and Risers
Heres a video of it running today.
Any ideas?
New Roller Lifters
Rebuilt Heads
Any ideas?
