I have a '93 4.3lx with the Weber carb engine serial #od841489. When I got the boat it had cold start issues and I figured out the choke rod was disconnected from the choke stove spring. So I take the carb off and the choke stove and reconnected the choke linkage and reassemble everything. Adjusted choke linkage and test. Worked perfectly. My problem is as follows... Before i did anything it was a hard start cold but once warmed up it ran great. It would jump outta the hole and plane up almost instantly. Now it backfires through the carb if you go to wot too fast and wot is now about 3000 rpms. I did adjust air/fuel settings per the online manual and did replace gasket. I didn't turn the carb over or anything like that. I just lifted it off the intake, raised it high to check the surface for any remaining gasket and set it down upright. Any insight would be appreciated.
