JoLin
- Aug 18, 2007
- 5,146
For the first time, I DIY'd a major service on both my Alphas. New bellows, water hoses, shift cables, trim sender/limit switches. Modified a motorcycle jack to R&R the drives. Built a pressure tester and as a result, replaced the shift shaft bushing in one drive. Literally spent DAYS adjusting the shift cables, climbing from the bridge to the swim platform to see if the props were spinning, to the ER to make an adjustment, then do it again, ad nauseum.
Launched the boat on Thursday (after a mostly sleepless night) and voila! No leaks, the drives shift fine, engine temps are normal, and had a great ride from the launch ramp to my slip. Can't vouch yet for the U-joint bellows. I'll know that in the Fall when the boat comes out. With my new jack and pressure tester, it'll be a snap to service the water pumps next year.
All in, including the jack, pressure tester, special tools (eBay) and parts (all Merc OEM) it cost me about $1.000., or half what the mechanic would have charged for the 2 drives. Next year's water pump replacement and general service should cost me about $150. That's a QUARTER of what it costs to have the mobile mechanic do it.
I could not, and would not have had the confidence to tackle this job if it hadn't been for this forum. The knowledge and advice one finds here is simply incredible.
Pretty happy with life right now.
