Do you know how easy it would be to modify an old alpha to accept the kit?????
What year/serial number Alpha drive?
If you have an Alpha drive that was made roughly between 1976 - early 1991 then I don't know for sure or believe the upper drive shaft housing can be converted/drilled out to accept the Spring, Ball and Seal Kit typically found on Mercruiser Alpha One Gen 2 and Bravo drives as these drives either came with or possibly more prefabbed to accept an oil reservoir system.
This kit in the following link is the check ball that keeps the oil from leaking while the stern drive is removed. It goes in the upper unit between the two top right (starboard) mounting holes.
http://bpi.ebasicpower.com/shop/inde...;products_id=5 729
I sort of recall what
AllDodge mentioned above about a past member being able to somehow add an oil kit to a drive without drilling through the boats hull like you'd do with Pre-Alpha kit number 69622A7....But I don't recall exactly what model stern drive he had or can't recall enough key words to search for it here on iboats or online...It may have been an older drive model as it did seem pretty unusual.:noidea::encouragement:
If it was a Pre Alpha type drive, then he would have had to drill out the transom assembly as the plug you'll be seeing below won't/shouldn't be there, the bell housing and the drive shaft housing...If possible.:noidea:
If you have the Alpha Gen 2 drive/transom assembly, then it would be a little easier to do as the stern drive should have the hole already in place with the spring kit already installed. The bell housing is a 50/50 of having the hole in place and you won't know until you pull the drive off.....If the hole is not there then a 1/2 inch drill will open it up to install the dribble valve as seen in the Merc-stuff link above and that valve comes in that kit too.
On the Gen 2 transoms, The hole should already be in place to install the bulkhead fitting by simply removing plug part number 22-73379 that looks like this,
http://www.ebay.com/sch/i.html?_from...3379+&_sacat=0 And that plug can be found in the general location of item number 14,
http://www.mercruiserparts.com/bam/s.../30858/1017/30
Also if the bell housing does have the 1/2 hole then you'll have to remove plug item number 4
http://www.mercruiserparts.com/bam/subassembly/30858/1017/50 And install connector item number 8,
http://www.mercruiserparts.com/bam/subassembly/30858/1017/170
