Slice of Life
- Apr 2, 2013
- 78
After trying to adjust my shift cable on the alpha one gen II, standard rotation, due to the end of last season having it occasionally stuck in gear when either going into reverse or forward, the prop still ratchets even after adjusting lower nut that was all the way at the bottom at first on the forward part of the lower shift cable. :mad-new: I went by the directions exactly, and watched achris's and SEI's youtube videos on the adjustment. With the nut either all the way down, or all the way at the bottom or a bit in the middle, it still will not go completely into gear.
When the gear is put into reverse, the prop will lock clockwise and move counterclockwise (albeit with a bit of resistance and a loud "clang" when moving) like it's supposed to. But when put into forward, the prop will ratchet either way still. Suggestions? Thanks.
