brodie123
- May 4, 2008
- 279
Hi Everyone;
Mercruiser 3.7L 224 L4 I/O Serial # B959792 Ford engine block
I'm trying to upgrade to electronic ignition and I was not able to find the correct distributor - I think now I was seeking the wrong one?
I called Pertronix and gave them the motor specs - they sold me a ML-141C upgrade kit for a Mallory 4Cyl distributor.
I went to install it but the plate with the pickup is too small and just sits on top of the weights and the plastic round magnet has too large of a diameter and does not fit. Obviously wrong unit.
I need to figure out what distributor I have. The only info on the distributor is a sticker that says SAE J1171 Marine which I believe just tells you it's approved for marine use.
Can anyone tell me what distributor I have?
What replacement electronic distributor I could use?
Or, what Pertronix upgrade kit I should have ordered?
thx!!!
thx!!!
