I'm getting ready to put the engine back in and am putting on a used exhaust pipe to replace the one shown in the picture, which had been gouged badly by the armoring on the lower shift cable. I have a new seal that is an oval o-ring that goes around the opening of the receiving surface on the gimbal housing. I see seals and pipes in some of the manuals that go around the two holes on either side of the center hole through which the black and grey hydraulic hoses pass. Those two holes go back into the gimbal housing to a dead end and seem to have no function. Does anyone know the function of those holes, as it appears that they are left uncovered when the pipe is installed?
Also, I don't see mention in the manuals about a sealant on the o-ring. Do any of you use a sealant here?
