adruid
- Apr 3, 2014
- 52
I'm changing out the distributor on a 1984 GM 140 hp 181 cid 4 cylinder engine. The distributor is a points type Delco Remy original and getting a bit sloppy. Want to make sure I use best practices and get the old one out and newer one in smoothly. Have been a bit confused about all the talk of "base timing." It appears the EST needs to be set like this, but I have a points type distributor with aftermarket Pertronix ignition. I don't see how these would need to be reset to a base timing, just TDC with rotor pointing to #1 cylinder. Any tips on the R&R and/or clarification of the timing reset question will be appreciated.
